Hi everyone.
I've had a good search on the forum about TRVs and found some very useful information, but I have a couple of questions.
My current system is a 24kW combination boiler running 8 radiators. The only temperature control I have in the whole house is the one located on the boiler pannel - which works well, but needs a lot of adjustment. All the radiators have standard manual spindle valves with lockshield valves and there are no room thermostats.
Obviously, this isn't the most energy efficient system, so I'd like to better it by fitting TRVs.
All my radiators are fitted with those angled standard chrome compression valves (PVC pipework) as per the picture below:
1. Does this valve have to be removed completely to fit the TRV or can the spindle and olive on my current valves be removed and the TRV fit into that? I'd like to fit something similar to the one shown below:
2. I understand that one radiator should not have a TRV fitted and be left wide open to act as a bypass. Is there any radiator in particular which should be chosen as the bypass? Maybe a radiator located in a warmish room (bathroom) to keep it from firing the boiler up all the time..?
3. Once I've fit the TRVs, what is the best way to set the temperature on the boiler? Should I set the boiler on full and let the TRVs do the work, or should I be adjusting both?
Cheers guys.
Chris.
Cheers guys.
Chris.
