Hello,
I am plumbing in a new downstairs loo using a macerator.
I have four questions:
1) The PVC 40mm pipe needs to connect with a cast iron soil stack. I have the tools (hole cutter, boss strap, 40mm adapter), question is what's the best substance to use as a gasket sealant between the boss and the cast iron pipe?
2) I am aware that the boss strap i have is designed for a PVC soil stack, and cast iron stacks are slightly smaller in diameter, so what is best to use as a bit of packing to ensure the boss tightens up nice and tight?
3) The pipe from the macerator has to go under a floor into the cellar, follow suspended from the cellar ceiling (solid stone), and out the old coal chute, along the outside wall and into the cast iron stack.
I have seen two installations already where the pipe comes out the macerator and almost straight up and out at least 3 meters on both installations, and from what I could see, thats means water would always remain in the vertical section of pipe
The macerator I have can pump up to 7m vertical, but is only going about 1/2 meter in total as it happens. My Q is as the pipe goes down first into the cellar, then up 1/2mtr at the coal chute, this in effect creates a U trap which would always have water in, doesnt sound good to me, although the instructions say its ok.
Is it ok?
4) What is the recommended fall gradient in the section that runs outside between where it emerges from the coal chute and plumbs into soil stack? (total length of approx 4.5 meters)
Many thanks in advance for clarification on these questions.
Jon
Is it ok?
Jon
