I have a query regarding the size of fuses to go in a FCU.
1) - I have an FCU high up on the wall outside the bathroom that isolates the supply to the main bathroom light (and pull coard switch) on the upstairs lighting circuit which itself is protected by a 5A fuse on the CU. What size fuse should be in the FCU? - at the moment it is 13A which seems pointless!
2) - Also, I have a similar situation for the en-suite. This has a light / switch for light and also a fan with its own one/off switch built into the fan - pull coard. Again what size fuse should be in the FCU? as at the moment it is 13A.
The upstairs light circuit is not on the RCD side of the board, and we have just moved in and noted the 13A fuse!!
Many thanks!
Many thanks!
