Ok folks first post.
My Baxi Bermuda boiler is not heating up the rads, but the HW works fine. When I switch on the CH system it runs for 5-10mins then stops. Slight heat then cuts out. I'll reset the system, but then cuts out again. The temperature gauge never goes above 35 Deg c when it runs for that 10mins. Also the HW will then goes hot and cold whilst the CH is running, but works fine again when switched off.
My suspicion is that the pipes for that line maybe blocked with the black crud, unless there is some other internal malfuction i'm not too sure.
Cheers
Anji
Cheers
Anji
