Just joined up to post a query I have with my central heating. i'm going to get an specialist engineer in from BIASI but I would like to eliminate a silly fault or set up first.
Moved into a flat and with it is a BIASI Combi Boiler for gas. I cannot find the model number or a similar photo online. I've found a manual online for the RIVA COMPACT HE and it seems similar although maybe not exact.
The issue is central heating is not coming on automatically based on the time values for the boiler. I wake up in the morning and it's freezing however the boiler should be heating the flat for 45mins prior to me waking up. I changed the thermostat to a digital non programmed and this morning it read 14 degrees, set temp 21 degrees and it was calling for heat.
So I checked the boiler and the timer display said on based on the current time and settings. The applicance Operation Light is flashing quickly which means a fault has been detected. For some reason without touching anything on the boiler I started the hot water tap in the kitchen and the boiler fired up to heat our water. The tap ran warm and then the radiators started to receive heat.
Is there a common cause for the boiler failing on timer and correcting itself when the hot water runs?
I know it's not ideal I cannot find the boiler model but hopefully the description of the fault may ring some bells.
Marcus
Marcus
