Meter reading hassles
4 Nov 2010
Cumbria
It's that time again at work. My employer rents 4 units in an office block, and so we have four supplies - all dual rate as the building is electric only (night storage heaters - one of the few things to challenge combi boilers in the league table of crappiest ever inventions).
Anyway, my colleague is handed three letters from the supplier (EDF) asking for meter readings (the fourth unit is on a difference billing cycle). Oh what fun, the account numbers on the letters are now different to what is on his spreadsheet - and there isn't enough information on the letters to identify which is for which unit. Cue phone call 1.
So he goes and reads the meters, which have counters labelled "Normal" and "Low". Logs into the website, to be presented with a screen asking for readings labelled "01" and "02". Cue phone call number 2 to find out which value goes into which box - it's been done wrong before and then we get some interesting bills :roll:
You'd think is shouldn't be beyond the capabilities of a system to hold a record of what meter type is fitted and present boxes labelled the same as on the meter - wether it's Day/Night or Night/Day, Normal/Low or Low/Normal, or Normal/High or High/Normal, or even just 1 or 2.
Just for good measure, they aren't all the same :? All the meters are the same, but for some reason the mapping between Normal/Low to 01/02 isn't consistent across the accounts.
2 sets of readings get accepted, the third just results in an error message saying the readings aren't consistent. No clues why or what to do about it !
Cue phone call number 3 to give the readings to someone in a call centre.
This is such a massive user interface fail that words fail me. I really do wonder how on earth they expect non-technical people to read a meter when they seem to have gone out of their way to avoid making it easy.
It should so simple to fix :
1) Include the meter serial number on the letters - that would be enough for us to identify the right meter, though I guess it's not required for domestic customers with only one meter.
2) Present the entry boxes on the website in the same way as they are on the meter. If the meter has Day & Night, label the boxes Day and Night (and the same way round as on the meter). All it needs is a simple lookup table between meter serial number and type, and then pull in a bit of web code appropriate to the meter type. They already appear to deal with multiple registers, so it can't be that hard.
It won't be the programmers fault - they'll just be working to a spec. It's either a systems analyst who just failed to consider the end user of the system, or it's a bean counter somewhere who thought they could save a few quid - even though it must cost them a lot more in handling customer queries.
Oh I feel so much better after a good rant :D
Never used EDF, and from that mess don't intend to either.
British Gas however do exactly what you want - when submitting meter readings online, the meter serial number is shown, along with the previous reading and the date of the previous reading, plus the property address that the meter is for.
I'm with BG in the flat, and as you say, more helpful. Dunno what they do with multi-register meters though.
The address isn't helpful when you've three accounts that are all for "Units 1-3 ..."
Just phone EDF and ask them to send a meter reader round ...
Did think of that, and ask him to go back and tell them that it was a completely unnecessary expense if they'd got their systems right.
On the other hand, it's possible (dunno, I'm not privy to the contract) that there's small print that effectively makes it a cost to the customer if you don't do the meter reading yourself.
Gas meters are virtually all the same, while electric meter's vary quite a lot in design and method of reading so one form does not fit all.Oh and of course EDF are inept.
I must say that it does not surprise me that you are having fun and games with EDF, I have come to the conclusion that even their meter readers do not know which is rate 1 and rate 2 and how they link to day rate and night rate, it has taken me about a year to get them to get their readings in a reasonable order. Oh well keeps people busy :roll:
