You will get a short between live and neutral when CH is ON. All this should do is blow a fuse.if number 4 in the programmer is connected to 2 in the wiring centre the programmer will probably be knackered as number 2 is the neutral block. I take it you have numbered the wiring centre from the left.
Looking at the pic of the wiring centre there are definitely strange things going on! I was going to go through them one at a time and identify what they did, but have decided it would be better to start again!
You have an S Plan system so here is the "standard" wiring diagram:
View media item 72
It's probably best if you disconnect everything and start again. First you have to identify each wire, which is best done when they are disconnected, otherwise you can get strange results.
