Anyone out there have trouble with a boiler stove gravity circuit?
Trying to pin down my little nagging problem - little to no heat rising up the gravity flow pipe. I've read dozens of pages on the subject - and of course no two systems are the same or reflect the same problems so I am relying on the hard facts of plumbing/engineering rules.
The stove is 14kw (9.5kw to water). The pipes are all done in 1" coming off the stove at the top left for the flow and bottom right for the return, as per the makers spec. The gravity is horizontal for 6' and then rises vertically for 6' into the ceiling joist void, where it is horizontal but rises about 5" over 8' to rise dead vertical again to the cylinder. Pipes are lagged in the ceiling. Cylinder is 240L triple coil. Gravity is to the secondary coil, Primary circuit is the pumped heating. Thermostat is on the Primary return, set to 50degC. Open vent is on the Primary. Primary circuit has an autoair vent and I bled the gravity for air also.
No suggestions of pumps please - we all know what gravity/pumped by definition means.
Any pointers welcome.
