Hi All
I am just looking to replace my hot water cylinder at home and the cylinder i am replacing it with is a economy 7 direct combination cylinder.
It is just a direct replacement for the one i have already. the connections on the tank i already have in are two conn for the emmersion heaters ,
one hot water outlet connection , one inlet conn which is the cold water and one right at the bottom which is the drain . now iam looking to buy a new cylinder and all the cylinder i am looking at only show the connections
for the emmersion heaters do they also come with the hot water outlet already in the cylinder & drain conn. I do believe you have put your own cold water conn in since the tanks are usually plastic .
ANY HELP WILL BE MUCH APPRECIATED THANKYOU
