A
aaronjb
That's the house electrics as I moved in - as far as I can tell, untouched in probably 20 years (house was built in 1970, I suspect the CU is original, central heating also probably original(!) and the black transformer for the original - inoperative - doorbell)..
Reckon I'm right about that being original?
Now the question really is - I've given up on the idea of doing any DIY (apart from anything else, everything seems to have been legislated out of the question!) so when the electrician comes around to quote for wiring in a feed to the detached garage (SWA under the drive etc etc) .. how much of this is going to have to get replaced in your learned opinions? (I know, I need a proper safety check before you can truly answer that.. but on first glance, if you turned up and saw that..)
Do the regs allow an unprotected run of SWA (as one electrician suggested on arrival), or does the CU need replacing so an RCD (RCBO?) protected run of SWA can be installed? If the CU needs replacing, there's the possibility that more wiring will need to be replaced and .. so on and so forth. So I'm hoping that the regs will allow it to be wired in with the minimum of disruption and without costing thousands (but as I'm learning, any time you think about doing something in a house it ends up costing thousands..)
