Hi, I have a BEKO DWD4310 dish washer that keeps getting stuck on drain mode. I have filled with water from a bowl and can confirm that it is not blocked as this drains ok. I have disconnected the hose from underneath and reconnected. I have also disconnected/reconnected the overflow indicator group (attached to the base) and even removed this a couple of times. This normally works for about a week before it fails again. Tried it tonight and it just got stuck on the drain. Any suggestions as its nearly as cheap to buy a new one as o get somebody else to repair. Cheers Jon
