Hi all,
One of the overflow pipes coming from the little copper tank above the hot water tank in the airing cupboard recently started dripping. No problem I thought, got a new rubber diaphragm washer thing and put that in the float valve. All tested and confirmed that it shut off the water at least a couple of inch below the first overflow. Next morning the overflow was dripping as the tank had filled up again and almost completely submerged the ball. Bugger. So I fitted a new float valve. Again fully tested and happy that it cut the incoming supply at the right level. Next morning same again, tank full and overflowing. Bugger.
Happy that the float valve was working properly I wondered if the water was coming in through the bottom outlet pipe. Luckily there is a ball valve before the float valve so I isolated the float valve, left it a few hours and sure enough the water level had risen and eventually started overflowing.
The problem I have is knowing exactly where that outlet goes to!
The rough layout of my water system is a Gas Boiler (Elan Ideal 2 NF230) in kitchen (ground floor), hot water tank in airing cupboard in bathroom (first floor) and small copper tank (the overflowing one) above tank also in airing cupboard.
Been doing lots of searching on here and the interwebz and apparently it may be down to a hole in the cylinder coil as suggested in the FAQ http://www.diynot.com/wiki/plumbing:faq:faq18
I can put some pics up of pipes, etc if it would help?
Any help would be awesome!!![/url]
