I have a 3 year old Triton Opal II (10Kw) and was having problems with a low pressure light. I changed the PCB and it seemed to solve all my problems and was working perfectly for a couple of weeks.
Now I notice that it isn't as hot as it should be on high setting. It doesn't matter if on medium or high the temp stays the same warm temp even though the red light is switching form red 1 to red 2.
I will check the micro switches on the PCB to see if they are switching properly first.
I have read that it could be one of the heating elements and I should check it with a multi meter. (I undersyand there are 3 in the 10 kw shower)
Can someone explain exactly how I would check them. I presime they are in the black water tank... how do I get to them and test them?
Can someone explain i detail what to do?
Having spent £60 on a PCB, I may as well keep going with this shower but may need some help.
