Hi all,
I have a 20a mains relay (<250v ac) with a 230v ac coil. The relay is the finder 22.24 as below:
http://www.findernet.com/comuni/pdf/S2221_22_23_24EN.pdf
The relay is normally closed and needs 230v across the coil to open the circuit.
The relay is going into a motorhome mains circuit and takes a low current live feed from a mains changeover unit to open the live and neutral on some circuits (split CU) when the inverter is used to prevent items such as battery chargers and air conditioners from being used from the inverter.
To get 230v across the coil shall I connect the live switching feed to A1 and attach the neutral to A2? or does the live go to both A1 and A2?
Thanks for your help,
Nick.
For anyone interested the changover unit used is this:
http://www.sterling-power.com/products-230vcs-auto.htm
It is a well built unit but I don't know how the DNO would feel about it's use.
Nick.
