I’m fully aware of that & it’s why I asked the question. Unfortunately in your quest to comply with Planning Regs, your plans for drainage will almost certainly breach local By-laws & is probably more serious but check with your LABC anyway.I'm block paving the front of my house, the regulations were changed in 2008 for front block paving and should have rain drainage?
You need to rethink your project; either fit a channel drain across the bottom of the drive running into a suitably sized soak away, lay a permeable block paving or chose some other permeable surface for your drive.
