Testing PCB transformer
29 Oct 2008
London
Hi all
What's the best way to test a transformer using a multi meter (PCB transformer)? What pins should be checked for continuity?
Thanks for your help
Jack
WHat boiler?
It depends what pins are on the transformer. Some only have 3, some many more, on both sides.
The low voltage side will be very low resistance. If it has shorted turns it'll be just a bit less - hopeless to try to measure it.
The only way is to know what voltages you're supposed to get, and see if they're correct. Then you really need to isolate it.
Some trannys are easy, eg a puma has 24vac output and when they "go" there's nothing.
Others not so.
so it's hard to test? ie no power going to APS it could be pcb OR transformer (is used) ... ? i'm trying to get the manual !! :)
Fail to see the logic in your thought.
Why would it need to be the PCB or the transformer? What are you using to test for voltages?
Measuring resistance on a transformer will tell you nothing. What will you compare the resistance values with- the manual is not going to tell you! You don't even say what boiler you have.
Me thinks you are in a different ballpark when it comes to fixing your boiler. Leave it alone and get someone who knows what he is doing, to have a look see.
giot it - no problem seen in the manual where to test for to check the transformer is ok and it is :) peoblem in end was no voltage going to fan - tested using multimeter across terminals at fan
Generally, if you have 240v at the primary windings, all you need to do is to test for the expected secondary voltage.
On many this will just be a single 24v secondary winding.
However, this is all past technology! Most modern PCBs dont have a transformer and use a switched mode power supply as they are cheaper and lighter!
Tony
do you find fault finding/replacing parts on the older style boilers, or the newer type (premix burner/zpg type) easier?
