Hi there
A few days ago my phones went 'dead'.By that I meant that there was no dial tone and when you called the phone it was engaged.
The internet still works luckily but according to SKY there is an internal fault on the line. I've removed the faceplate on the master socket and get a dial tone which I think confirms there is an internal fault.
Question is how do i know go about finding where the fault is and fixing it- I don't fancy a £200 call out from BT!
The system is set up with one master socket downstairs installed by BT and a second master socket upstairs (also installed by BT). They are both on the same line.
The socket master downstairs leads straight to an extension which has been chased into the wall, There is also another feed into the house (where the original master socket was) which is now a regular junction box which leads upstairs to the second master socket. That feeds two more extensions- one in the loft and another one on the same floor. Just to confirm the master socket upstairs does not have a dial tone when the face plate has been removed so I'm fairly sure this should just be an extension box which feeds the other two boxes.
Here's how the wires were looking:
downstairs master socket:
green (2)
orange (3)
wht/orange (4)
wht/green (5)
upstairs:
blue (2)
orange (3)
wht/blue (4)
As far as I understand you only really need the correct wires to go into number 2 and number 5 as 3 is for ringing and 4 is not normally used.
Now I have just connected 2 and 5 downstairs and unplugged everything upstairs but no luck which is not a big surprise!
Any advice would be greatly appreciated. Is there any chance the faceplate could be faulty or will I have to open up every extension and check that the wires are in connection number 2 and 5? Am really hoping i will not have to hack into the wall!
green (2)
orange (3)
wht/orange (4)
wht/green (5)
upstairs:
blue (2)
orange (3)
wht/blue (4)
