AEG Oven Connection - Neutral Connection?
4 Aug 2011
Devon
I have recently had delivered and AEG built in oven.
I have disconnected the old oven and am attempting to connect the new oven. The existing oven flex, and connections are fine and I was hoping to be able to simply be able to connect the new oven.
The trouble is, on the new terminal block, on the neutral terminal, all three pins are taken up with existing connections - there is nowhere to connect the neutral pin connector to! The earth and live both have spare pins.
See the photo in the album below:
http://www.diynot.com/network/wahoon/albums/
[/wiki]
What does it show in the instructions?
Also make sure those screws are really tight.
I have just seen one which was completely burnt away.
What output is the oven?
what size is the cable supplying the circuit?
What size is the breaker that protects the cable?
Just seems strange that I can't use the connectors that are already on the wire (they fit on the live and the earth)
You probably can but you have no spare for neutral, so that must be connected some how, do you have picture of the end of the flex with the connection on?
Hang on there. I have just re-read your opening post.
Are you saying that you have transferred the cable from the old oven to then new?
Are you sure that this is the right size cable for the new oven?
If it is and there isn't spare way on the terminals, you don't have much choice do you?
As others have asked, what do the manufacturers instructions say regarding connecting the cable to the new oven. I know it will say L to L etc but it should say how you make the connection - sometimes as PrenticeBoy has stated and sometimes by crimps.
and which type of crimp and crimping tool would you suggest wahoon uses
Well that will depend on the cable size - since we haven't been told it yet.
As for crimping tool, well don't use your teeth, but use a ratchet crimper - its on the same page.
My teeth often do a better job than some of the more poxy crimping tools.
Just trying to get all the info that op may require to get his roast spuds on!
That's the weird thing. I can't find any guidance in any of the manuals supplied with the oven, or online. There is a sticker on the back, giving the obvious (L to L etc.)
