    Dismiss Notice
Double Oven Wiring Connection
Discussion in 'Electrics UK' started by RevRed, 14 Apr 2015.
  1. RevRed
    RevRed
    14 Apr 2015
    4
    Thanks Received:
    Country:
    My new double oven has 2 Live, 3 Neutral & 1 Earth connection. The existing wires from the wall connection only have one of each. How do I connect the oven?
    RevRed
  2. Sponsored Links
  3. riveralt
    riveralt
    4 Jan 2004
    4,020
    Thanks Received:
    597
    Country:
    What do the oven's installation instructions say?
  4. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,105
    Thanks Received:
    2,066
    Oxfordshire
    Country:
    What he said
    ALSO
    Inside the connection box you should find some brass links. They will need to be used to link out the live and neutral terminals in a particular way.
    The way you link them will depend on the type of supply that you have.
    It will be in the installation instructions, and sometimes inside the termination box.
  5. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,628
    Thanks Received:
    2,383
    Londonderry
    Country:
    Are you sure it is not 3 lives/2 neutrals?
    Your oven has been designed to either deal with different numbers of phases, the electrical wiring instruction that come with the appliance should show how to wire yours to single phase.
    Or there could be a diagram near the terminal box on the appliance.
  6. RevRed
    RevRed
    14 Apr 2015
    4
    Thanks Received:
    Country:
    The instructions only contain a wiring diagram, which I do not understand. See a copy attached.
    RevRed
  7. RevRed
    RevRed
    14 Apr 2015
    4
    Thanks Received:
    Country:
    RevRed
  8. Sponsored Links
  9. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,105
    Thanks Received:
    2,066
    Oxfordshire
    Country:
    I assume that you have a normal (230V) single phase supply to your house and kitchen?
    If so, your cooker is already configured with the links in place for connection to a single phase supply.
    You connect the live to the terminals marked L, the neutral to N and the earth to the earth terminal, using the cable that is specified by the maker in the instructions.
    It cannot be more simple.
    If you can't cope with this then you need to get an electrician to do it for you.
  10. RevRed
    RevRed
    14 Apr 2015
    4
    Thanks Received:
    Country:
    Hi TTC,
    Thank you.
    Yes, I presume the existing wiring is normal single phase.
    Can I just confirm that I need to split the wiring from the mains to connect the live wire to BOTH live connections on the cooker, and the Neutral wire to ALL THREE neutral connections on the cooker. The earth is an obvious one.
    If I do need to split each wire, is there an easy way of doing this?
    RevRed
  11. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,628
    Thanks Received:
    2,383
    Londonderry
    Country:
    As above, the links are already factory fitted, simple job of fitting correct cores to correct terminals.
    That would depend on core colours
    Brown or Red= Live
    Blue or Black = Neutral
    Yellow/Green or Green = Earth
    I assume you have the correctly sized conductors and rated fuse for the appliance.
  12. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,628
    Thanks Received:
    2,383
    Londonderry
    Country:
    No splitting of cables required, just install each cable to one of the designated terminals, the factory links will do the rest.
  13. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,105
    Thanks Received:
    2,066
    Oxfordshire
    Country:
    And a big enough supply!
  14. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
