RET-BZ + RXZ1
  • Thread starter Thread starter Dark
  • Start date Start date
D
Dark
Hi I need help, I have new Danfoss RET-BZ + RXZ1 I want to replace may old thermostat (24v) is it possible to change? My unit is water chilled fcu, pleassssssssssssssssssssssssss help :roll:
the reciever unit (RXZ1) needs 230vac to work, it will switch 24v but I would advise that you get someone to install it for you (no offence).
Quite simple to wire, and you adjust the dip switches for the required cooling loads.
they are straight forward to connect but the op must have the instructions and still has to ask if it will work on 24v, I would suggest he/she gets someone to install it for him/her.
Wonder which database Agile is checking "Dark" out on. :lol:
