i can't find an exact answer to this so apologies if I'm covering old ground..
I've fitted a new bathroom and of course the last part of teh installation is the shower unit.
My house has a normal vented system - Y-type. The shower has about 2-3ft of positive head. The water in to the bathroom is a 15mm cold and 22mm hot from the tank which I've tee'd off to the bath taps and used swept bends rather than elbows until the final shower inputs. The hot water feed is reduced however to 15 mm after teh bath for the final stretch as teh inputs to my thermostatic shower unit are both 15mm. All pipes have been boxed in and tiled over.
So far so good, I think (I am an amateur after all).
I had intended to install a single impeller pump under the end of the bath as I already have a suitable electric feed which used to serve an old electric shower. reasoning for putting it under the end of the bath is that the airing cupboard is in my daughter's bedroom and I don't want it to disturb her. The pump is on order.
Now, however, I've just found out about Venturi showers which seem to be an even better solution on the surface.
The New Team Jet Stream venturi type shower looks good, but requires a 22mm hot feed according to teh instructuions I've found on line. Am I going to get the benefit from my already reduced 15 mm hot feed or will it end up a false economy?
The Trevi Boost looks even better but, having already routed my pipework I think it would be too massive a job to get the pipework to fit.
I've also seen on other forums that I may have problems with my original solution?
