Hi
I have a towel rail radiator (one that looks like a ladder) in an upstairs bathroom which acts as a heat sink and, consequently, is permanently on. A week or so ago I noticed that the top 2 bars were only warmish, whereas the rest of the bars were very hot, so I bled the air out and the bars were instantly hot. I had to repeat this over the next few days, as the top 2 bars were going back to lukewarm. However, now the top 2 bars are almost cold (the rest of the radiator is very hot) but I can't get any air to come out of the bleed valve at all. I've turned the screw until it's all the way out but....nothing. I've had a look at the valves at the bottom of the radiator (didn't really know what else to do!) and found that one of them, on the right as I look at it, seems to be static although the white knob has + and - signs on. The other one, on the left, can be turned either way, so it's not fully open. Should it be? Even so, I don't understand why this radiator would bleed before and become hot all over and now it won't.
I'll give you what I know about the system (bear with me...I'm not a plumber and I'm only a girlie!!). The system is run by a Rayburn in the kitchen. It runs UFH downstairs and a radiator system upstairs (although no radiators are fitted at the moment, just pipes up out of the floor). The radiator system upstairs is turned off. Then there's this heat sink raditor I'm having trouble with. In the airing cupboard upstairs there are 2 round things; one white and one red. I don't know what they are but we've had differing advice on them. One person (a 'plumber'...I use the term loosely!!) told us that the white one needs bleeding every now and then as it will get air in. He was supposed to show us what to do but never came back!! Then we had a man from Eon here (due to a gas leak) and I picked his brains about this white round thing. He said that you can't bleed them and didn't know what the other guy was on about!!
Well, if you're still reading this and not bored to death by now, can you give me any advice? I'd be very grateful for any!! Thank you so much.
