Sorry I'm not getting the point of bypassing the pressure switch - the pump runs without any problem whenever heat is being called for anyway.
The Vokera's generally need a half bar to activate a low pressure switch to stop the boiler firing if the system empties or pressure is too low. In some parts of Ireland they are fitting the boilers to the domestic cold water storage tank in the loft which is not high enough to provide .4 of a bar pressure in the boiler (what Vokera set the switches to in Ireland) so installers link the switch out so that the boiler runs.
How many tanks do you have in the loft?
It sounds as though the low pressure switch has been disconnected on your boiler.
With a NRV in the cold feed no matter whether there are one or two tanks in the loft you now have a sealed system as there's only one safe place for the pressure to be accomodated and that is the expansion vessel. If the vessel fails or loses charge the boiler will vent from the pressure relief valve into your house.
If for some reason a leak developed or the pressure relief valve lifted should the low pressure switch be linked out the boiler will fire even though there's no water in it.
God knows why they do it like that over there I'd never heard of it before until I went over there. I work for Vokera and guys I've spoken to say it's common in Dublin but I don't know why.
If I was in your situation I'd get the PRV run to a safe position and connect the low pressure switch then charge the system to over .5 bar.
