Hi guys,
About 2 months ago I used a reputable electrician/company to replace an old Wylex fuse board with a new consumer unit. We've got a 8.5kW electric shower which is fed from a 6mm^2 cable which, if I remember correctly, was connected to a 30amp fuse. This has now been replaced with a 32amp MCB.
I've just had an electrician round to quote on moving the shower/installing an extractor fan and he reckons that the MCB is too small for this load. I've worked out that the shower (switched on to the hottest setting) will pull 35amp so he's correct in saying this. He then said that it's dangerous as the cable has the ability to get warmer without the MCB tripping? Surely this is the wrong way round and that the MCB will actually trip sooner and probably won't allow us to use the shower on max? (i.e. without any compromise on safety).
He did only have a brief look and said to check it out but I'm confused...
On a side note, we have an isolation switch for shower on the landing. He said that a pull cord would be better in the bathroom. I'm not doubting him on this at all (and have actually got him to quote me for this) but what's the regulations on this, and what's the "norm"? Is it worth scrapping the isolation switch and changing to the pull cord?
Cheers,
Paul.
Cheers,
Paul.
