Greetings to you all, i have a simple question best way to paint over varnished doors they are reasonably dark doors but mother wants them now in white!, once prepared is white matt emulsion or white gloss best as the top coat? thank you
There is often a myth with regard to the applying of paint over a varnished surface, when really all that is important to remember is during prep it is important that you do not break through the varnish.
Using 240 grit wet sand/flat back the surface wipe down and allow to dry, then you should apply at least one coat of an oil based undercoat lightly sanding between coats, the stained woodwork will now be ready to accept the finish coats.
Emulsion paints are not really the way to go here and if I were you I would avoid their use, another alternative would be to use Crown Solo and if your painting skills are good enough you could well skip the undercoat and after the inital prep apply direct.
Dec
I remember seeing that test myself, I have a feeling it was either the screwfix or bibs & braces forum.
Dec
Dec
