Hi, my 1905 house suffers from some damp walls inside, as there was only 1 airbrick on the front of the house I put one at the rear and 2 on the side to aid ventilation through the cavity. It's an end of terrace. A nice draught flows through all the airbricks.
I found a slate DPM on the inner wall but not on the outer, none of the rubble I scooped out when fitting airbricks seemed particularly damp or mouldy etc so wonder if the concrete floors in all ground floor rooms are likely to be the cause of the damp?
Anyway, would it help to fit more airbricks, maybe higher up (I have a balcony which would allow easy fitting) or should I see how adding 3 airbricks goes when the next bout of rain crops up?
Any comment welcome!
thanks from this DIYnot newbie!
