how do i convert an existing set of 2 way switches into 2 one way switches?
Why would you want to do that?
A little more info would help, what are your intentions?
The two spots will need to be removed from the rest of the chain of spots,
then a supply live neutral and earth then linked across the two spotst and switch drop cables to the switch.
The chain should then be link/connected back to rest of the lights for continuity.
that was me that wasThe two spots will need to be removed from the rest of the chain of spots,
then a supply live neutral and earth then linked across the two spots and switch drop cables to the switch.
Is this room:We currently have a room with 60 spotlights in it.
a) The size of a football pitch.
Or
b) An example of how stupidly useless and wasteful spotlights are at lighting up rooms.
Can't see it being in a private dwelling then, in which case there are all sorts of legal issues - possibilities include the EAWR, licensing, public liability insurance conditions...
Get an electrician.
It is an 85m2 extension....none of the above apply (sorry) My electrician is on holiday...hence the request for advice
That's it!! - I'm going to become an electrician...........they get more holidays than teachers, if you go by the posts on this forum!![]()
