Can someone kindly tell me if I have this correct for the switched live connection? I have some brown sleaving for the negative.
In addition for some reason 2.5mm cable was used from the rocker switch to the JB. I should be able to use 1.5mm shouldn't I to make it a bit easier to route to the JB?. I mean 1.5mm is used for the feed and it's fused down to 3amps at the spur.
Do I have this right?
Thanks all.
Allan
Thanks all.
Allan
