Bathroom Extractor Fan Wiring Advice
3 Sep 2010
Avon
what is the best way to wire a bathroom extractor fan, do take the power from the light rose straight to the fan or shall i have a fused spur from the light then to the fan.
which is safer and why.
thanks
Neither is 'safer'. It depends how you want it to work.
Also, the manufacturers instructions may require the use of a fuse although not electrically necessary.
Do you want it to come on with the light and has it a timer for over-run and/or a humidistat?
i would like it to come on when the light is on , it has no over run or humidity.
I want something that will stop the fan from catching fire if it gets stuck as believe most house fire are stared this way.
shall i use a 3amp fuse.
Then just connect the fan cable wires at the ceiling rose/fitting to the same terminals as the actual light bulb - plus earth, of course.
You will need a double-pole switched fused connection unit so that it will disconnect both live and neutral when you switch it off.
Place it on the wiring between the light and the fan.
Yes.
one of these
