In that case there should be no issues with finding out why the boiler does not work. Operation is sequencial. You have a halt in this sequence. Get the multimeter out and with aid of boiler manual it will be easy to locate the defect.
Tony are you gas safe mateThere is obviously a fault!
But I am surprised that you are using hot water for so long and so regularly.
There are several possibilities as to why the boiler is stopping. Knowing what makes it come back on would be a clue!
Obviously correctly diagnosing the cause is the first step in repairing!
Tony
Well, I read the forum mate, just seems everything is gained via here oh and the name is a clue. Anyway it's a legitimate question ain't it?Blooflame. what makes you think our Tony is not Gas Safe registered?
He is Argi registered (see his signature)
No one has fiddled with any settings on the boiler (I presume you mean the other screwdriver adjustable potentiometers)By the way, has anyone been fiddling with the boiler settings?
