My girlfriends boiler was working fine then work up in the morning and no heating or hot water, the hot water started working in the end but the heating isn't. The boiler is an Worcester 24i combi its an old one with a grey bottom bit for the dials.
I can see the boiler firing up when the heating is turned on but the blue flame goes after a couple of seconds, if I leave it does the same a couple of minutes later the rads never heat up, the room theromstate and boiler one are set high. A couple of questions,
1. The pressure gauge is at 0 should the pressure dial rise when the heating is on or should it always be higher than 0 even when off ?
2. The boiler instructions mentions a reset buttom top of the boiler at the front left, I had a look and there is something there but it doesnt look like a button, it looks like of a bolt as it has a thread on and it doesnt seem to press down. Is this the reset button and if so is it may be missing a bit or should I just be able to press this down ?
