Hi I wonder if somebody can help me. I have a vaillant Turbomax boiler which is about 4 years old. It worked perfectly for 3 years but now causing problems.
It tends to switch off every now and then and in the info display reads a code of \\\"s33\\\" - which stands for - \\\"check flu/air system\\\". The flu looks fine (it goes through the ceiling into through the roof. the boiler is located in the airing cupboard between the two upstairs bedrooms(where the old water tank was located) in a standard 1930\\\'s bay fronted semi.
I recently asked a plumber to come and have a look, he said that the boiler needed servicing - which he did for me at a cost of £50. He said to keep the door of the airing cupboard open, as if it is closed the boiler will think that the temperature is too hot and will not switch on - I\\\'m not sure if i believe that.
Anyway, the boiler seemed to work fine for 1 month after the service, but now the problem has returned. I have been keeping the door of the airing cupboard wide open, but it still cuts off and diplays the \\\"S33\\\" code.
Does anyone know what could be wrong?
P.S. This seems to happen more on days that are very cold, also, it tends to switch on for a while on its own then goes off again. I have already tried to re-set it - but this doesn\\\'t cure the problem.
