Copper pipe
18 Nov 2011
Shropshire
Having just moved in to a house (10 years old) there are a few pipe bursts in what I thought was 22mm pipes, but having bought some pipe and 22mm couplers to repair them dont quite fit the existing.
What size could my existing pipes be if not 22mm?
3/4" imperial. It's slightly smaller.
You can get 3/4" olives to go in 22mm compression fittings, or use the 22mm olives and give them an extra heave before they tighten up. Solder fittings will not work though - but you should be able to get imperial/metric couplers at a plumbers' merchants for pence.
I think toolstation do them as well but in packets of a million (well, 25). I got a couple from BES recently.
Cheers guys.
Smaller? Just to clarify....Am I right in thinking imperial is slightly larger then?
I purchased the 22mm metrics today from merchants and the existing pipe (3/4"?) is very slightly too large to fit the purchased ones
Hi cantaloup
Yeah the property was not drained over the winter apparently and it got down to -18 here.
Water was off when we moved in, turned it on and hey presto like a caulinder lol
By how much larger than 22mm is your mystery copper pipework?
Wondering if the freezing has expanded the pipes a bit in places.
Oh its only mm's too thick - like you said thicker walls
Offering it up it just doesnt quite fit either the push fits or the solder rings....... frustratingly!
Oh expansion through freezing - right is that a possibility
That would make sense - thanks a lot
I guess I will have to replace larger sections than I anticipated
Only a theory. Did the pipes split in the vicinity of your repairs? Or are they pin-hole style leaks?
On the 22mm length I am struggling with they are split leaks.
I cut out sections about 3" either side to couple and link with new pipe
I guess if it has stretched then it will need more cut out
