Does anyone care to quote to balance my radiators?
I have 8 radiators in total and live in Kent
Are you being serious?
You could do this yourself with a bit of guidance.
If you are still unable to do this, get back to me.
You will not get far with a career in plumbing if you just tell your customers to do the work themselves!
An explanation of how to DIY is given in this site's FAQs. However many people still prefer to have it done professionally.
Usually either because they want it done professionally or there are difficulties because of system deficiencies.
Tony
I guess soAre you being serious?
Shut all valves on all radiators.
Then start with the radiator closest to the boiler.
Open the valve slightly. Then go to the next radiator. Open valve a little bit more then the 1st rad. Then go to the third rad, open that valve a little bit more then the second. Keep doing this, opening each valve a bit more than the previous radiators valve.
The last rad should be open more than the others.
See how the rads heat up and adjust the valves accordingly, you may need to open each valve a little bit more, or close some a bit more then others. This is balancing the system.
This will mean the hot water will be forced through the first rad, forced through the second etc etc. You need to force the hot water through to the furthest radiators.
If you were to open the first radiators valve fully, most of the hot water will simply circulate through that rad with very little going to the others.
The pressure diffrence being created by the pump, which pushes (exerts a force on) the water as it goes through the boiler. I guess its a moot point, you could forinstance say the water is forced the radiators, but not through each radiator.... Ok, im playing devils avocate, but hey ho!The water is not "forced" though a radiator. It goes though because there is a pressure difference between the flow and return connections.
