Russ Andrews eat you heart out!
I'll have 2.
I'll have a few hundred m on a reel please, and use it to rewire my entire house.
Maybe I should change my signature to
There are no exemptions from the laws of physics on the grounds of gullibility.
However the Odin, the result of over five years of research and development into wideband signal transmission, makes the Valhalla look a positive bargain with its price tag of £20,495 per 5m.
If 60Hz is "wideband," I wonder what narrow band is?
The separate, solid-core conductors eliminate strand interaction, hot spots and other artifacts that can degrade performance
Presumably they also somehow eliminate these characteristics in the plain old copper #14 or #12 wiring from the receptacle back to the distribution panel as well, not to mention everything which goes before that. That's quite a feat.....
While do I believe from my own experiments cable does make a difference to sound this is just over the top.
The best thing you can do mains wise is run the HIFI from a dedicate circuit rather than the ring or radial.
Still amazed Russ Andrews has not been closed down (in my personal opinion!).
I wonder if they have introduced the Audiophile grade consumer unit yet?
The RA website has such an item - it's a Hager unit, and the addition of a RA label on it means the price is 10x greater.
£156.00 for a small RCD incomer board and one MCB.
Read this guff!
Please note: The installation of any mains circuit must be carried out by a competent electrician, holding Part P of the 17th Edition IEE Wiring Regulations (BS 7671).
SPECIFICATIONS
• Number of conductors - 16 (eight Live & eight Neutral, colour coded brown & blue)
Total live or neutral conductor diameter – 2.906mm (6.63mm²)
• Conductor material - Hyper-Pure OFC Copper
• Cable rating - 30A (7.65A per mm² @ 20ºC)
• Central Earth wire - 1.5mm²
• Total cable diameter - 10mm
• Insulation - Teflon dielectric
The cable is supplied in single insulated form. For installation purposes the cable must be double insulated, which can be provided at additional cost. To order, click the link at the bottom of the page.
ROHS Compliant
We recommend the cable is installed in conjunction with a 16A circuit breaker.
