Iv posted before and managed to get my boiler fixed by an engineer after some good advice. I need some more help. If i set my boilers central heating to come on and set the boiler dial at 65c my boiler takes 38mins to reach 65c from cold. Is this right? It also keeps at 65c for over 40 mins after the inital 38 mins before it anti cycles. The reason i ask is because my boiler is using 1.49 m3 metric units of gas per hour every hour. Shouldnt the boiler get to 65c quickly. How much gas should i use when its set at 18kw. We have gas rated over two mins and the rating showd that it is using the correct amount of gas. However it continues to use this same rate of gas ie 0.072 every 2 mins and does not reduce which is making it use nearly 1.5 units an hour. Help would be appriciated. How long does ur vallient take to heat up? Does it rev up to temp quickly like the water does ?
