Thanks. I don't have an unvented cylinder though, I have a thermal store.
To confuse the issue more, today I measured the pressure from my outside tap which comes off the mains before this valve. It measures 3 bar, so if the pressure is already 3 bar why then install a valve that limits it to 3 bar??
( The whole system was installed by my plumber about 6 years ago. He has now emigrated so uncontactable!)
It may well be that the manufacturer specified installation of a PRV if your mains pressure is likely to exceed 3 bar. Plate heat exchangers also have pressure limits, hence a PRV is common upstream of a combi boiler (or a heat bank).
When I bought the flat, the PRV had failed (the valve seat had eroded, and so it didn't properly shut off). With no water being drawn, the pressure would regularly be off the scale which stopped at 6 bar. The PHE in the combi survived it though.
And as Onetap wrote, it can make the system more user friendly be reducing the tendency for the taps to do an impression of a crowd control water cannon
