What to use to fill channels in concrete screed
16 Nov 2010
Norwich
Hi all
Today a plumber has relocated my stopcock to the corner of the room. I know have a channel in the floor screen which is carrying the pipe to the new stopcock location.
I am going to be laying underlay and laminate above the channels so can I use a materials to fill the channel which is not permenant (so I can get to the join should there ever be a leak) or should I fill the channel with a cement/sand mix?
As I am not an experienced DIY'er can I used a ready mixed concrete repair mortar?
Mark
Should be a permanent as long the joints are done correctly eg, solder type and not compression fittings, use sharp sand and cement, if you're not sure of the ratio mix, I think Wickes do sharp sand and cement in the same bag (normally 2 small bags of cement inside). The next problem would be that the new sand/cement will need to dry out 100% otherwise the laminated flooring will swell up because of moisture content, normally 1mm thickness per day! Make sure the pipe are protected with the correct wrapping tape
The pipe is covered in a lagging protecting it from frost.
The laminate flooring will not be going down for another 3/4 weeks anyway so that shouldn't be a problem and we'll be used fibreboard underlay aswell.
I need to ask a really dumb question..
Do you need to add any water to the sand/cement mix to fill the chased channel in the concrete screed? And do I need to add pva to the chased channel to aid bonding??
A bit of water but don't make it too wet. Damp down the area in the channel.
