Samsung cool n cool fridge freezer RL33SBNS
17 Dec 2011
Angus
My Samsung Fridge freezer was working fine until 1 week ago when it suddenly defrosted and I had to throw out the contents. There was some excess ice which I removed but now when I turn it on it seems to work OK for several hours and then it just stops again and warms up.
Any ideas?
heeelllooo and welcome robinps :D :D :D
suspect the temperature is to low in the room around 6 to 13 degrees
so the fridge is happy and the the cooling will not happen very often
warm the room to around 15 or 16 degrees and see what happens
Temp in the room is immaterial, fridge is insulated from exterior temp or would not work as a refridgerator. The internal stat may have failed.
if the room temperature is between o and 6 the fridge will be happy and never need cooling possibly for months on end :D ;)
insulating simply reduces the speed that heat transfers
FREEZER
all depend on how its set up its a fridge freezer that may only have one compressor hence the suggestion to warm the room to see what happens ;)
Makes no difference. Will run in a freezing garage or outside in the sun.
if the thermostat that controls the compressor is in the fridge i will only work when the fridge needs cooling
Thanks for comments
The ambient room temp is about 14C and no different to before. The fridge/freezer mechanism seem OK and it works for an an hour or so each time I re-boot. Then it just stops - the light are still on and there is no alarm, just no heat exchange and the both fridge and freezer warm up
Presume it is a thermostat problem. Is that easy to fix/replace?
