accenta g4 mini programming
13 Nov 2010
this panel have 3 programs. its possible to have one for daytime and another for night rite?
if so how does the user select between the programs? i need to be able to omit certain zones at night eg bedroom pir [/code]
If programmed to set in different ways omitting certain xones etc, punch in your user code and "Program 1 Set" At this point press the P button and the screen will present Program Set 1, 2 or 3 Choose your program and its should set the way the installer set those programs to set.
why doesn't this work for me? It beeps at me as if I pressed the wrong button.
I've already setup the program2 the way I want it. However am unable to select it when Itype in the user code.
Oh! Could you provide instructions / tell me where it's in manual. It's my 1st time setting up a panel.
Set up all the used zones on P2 remembering to disable the landing & any bedrooms, Also if they have anybody working shifts or unusual hours set the front door as timed & also any PIRs near keypad to timed as well,
When you have set up the zones programme the exit mode to 3 this will then be silent exit time so you don't disturb the house. You havent set up an exit mode so thats why you cant turn on part set
