Recently my front door has become increasingly hard to open and close. It was catching the stormguard attached to the sill.
The wooden door was fitted at the same time as the sill 2 years ago and fitted fine. At first I thought the bad weather had caused the wood to swell (Is this possible? It does need staining) closing the gap between the door and the stormguard. This has gone on for a month now and I was worried the door would be damaged due to the force required to open and close it so I removed the stormguard to investigate.
View media item 41516
View media item 41518
Permanantly removing the stormguard is not an option as there is about 1cm of daylight under the door when the stormguard is removed.
The sill that the stormguard is attached to has come loose from 2 of its 3 fixings. I have attached photos.
View media item 41515
This shows one of the fixings. It appears that 2 pads were laid on the course of bricks and the sill was attached to the pads using some sort of adhesive.
Is this a normal construction method?
My options are to reattach the sill to the pads using adhesive and hope that this will give me the 2-3mm needed for the door to clear the stormguard. What adhesive would I use?
Or remove the sill and shave a few mm off it using a wood-planer before reattaching it. Either way, I'll give it a sand and apply a few coats of wood-stain to it.
Advice please?
Advice please?
