I quite agree JohnW2
Sometimes I think BAS forgets to take his medication.
They are not fixed appliances. And plugging them in does not go against the guidance in the Wiring Regulations.
A portable heater IS a non-fixed appliance.
What you've suggested however is not a portable heater, its a heater thats bolted to the wall, ie fixed.
AFAIK the wiring regulations suggest that large fixed loads such as heaters should not be connected with a plug, and instead hard wired with an FCU or similar.
We've discussed this topic at some length in the past, and it certainly seems that there are some grey (or contentious!) and/or seemingly anomolous areas.A portable heater IS a non-fixed appliance. What you've suggested however is not a portable heater, its a heater thats bolted to the wall, ie fixed.
Fair point.
However the original suggestion that the heater did not come fitted with a plug nor flex would surely indicate that it was intended as a fixed appliance. Portable appliances would surely come pre-fitted with a plug?
Appliances
Regulations now ensure that all domestic electrical appliances are fitted with a plug from new.
All manufacturers and importers are required to ensure that electrical items they supply are fitted with UK three-pin plugs with the proper fuse. The only exceptions to this rule are for certain fixed electric lights, appliances intended to be permanently wired into the mains and appliances with an RCD plug or plug transformer. Distributors and retailers must not sell any appliances without a correct fused plug fitted.
Yes, I agree that the original description probably doesn't qualify as a portable appliance, for the reason you give - indeed, the absence of a cable rather suggests that it is only intended to be used 'fixed'. However, the most recent parts of the discussion related to portable appliances, so that's what my response also related to.Fair point. However the original suggestion that the heater did not come fitted with a plug nor flex would surely indicate that it was intended as a fixed appliance. Portable appliances would surely come pre-fitted with a plug?
I think (but am not certain) that this only applies to appliances which come supplied with a lead - and was designed to outlaw the previous 'UK norm' (effective for all of my early life) of supplying appliances with leads but without plugs. Appliances designed to be 'fixed' or 'built-in' (e.g. many ovens, oven hoods, extractor fans etc. etc.) come without any lead - but I agree with Aragorn84 that those probably cannot be regarded as 'portable appliances' - even if they 'could be used as portable' if someone connected a flex and plug. ... but I may not be interpreting correctly!From Trading Standards Website:Appliances
