No, it was a perfectly genuine question, which only becomes mischevious if you're feeling guilty! What I meant by "if he did?" was that, before the SP issue was raised, you were implying that having a meter with an isolator 'saved' you from having to arrange those visits - so you would not have had to arrange them!What do you mean "If he did"? If he did, he would. If I didn't know better, I would think you were just being mischievous.![]()
Whatever, I have to say on the few occasions (none recently) I've seen a DNO person called out to 'isolate' an installation whilst work was done on it, I'm pretty sure that they have merely pulled the fuse, and left the neutral untouched. For true isolation, they obviously should disconnect the neutral as well - is that what they do routinely these days?
