Hi
I've just replaced an old analogue honeywell thermostat with a honeywell CM927
I followed the wiring picture, but unfortuantely can't get to the boiler end of the wiring to check the colour coding, but followed this thread - exactly the same setup. I have brown/grey/black rather than brown/blue/black:
http://www.diynot.com/forums/viewtopic.php?p=1445948
After wiring, there was no power to the thermostat at all. I therefore wondered if the old wiring wasn't quite right. As such, I reversed the grey/black - assuming that one was neutral and one was the switched feed.
This worked and lit up the relay box. However, even when the relay is set on (green light on) the boiler doesn't fire up at all. I have the timer on the boiler set to always on. I've also noticed that the cm927 only has power if the boiler timer is 'always on'.
I'm now wondering if the wiring is still incorrect, but before I start randomly changing things wanted to check if anyone had any ideas?
Getting cold now...!
