Hi guys I need some help here deciding what im going to do,
I have bought an electric shower to replace an old one but after buying the shower I then discovered that my cable is not man enough for the job 6mm cable in instead of 10mm however thats not the problem i can sort that one out,
My problem is on the old shower set up there is no RCD installed before the MCB just an Isolator switch inbetween,
Now do I install an RCD so the run goes MCB->length of cable to RCD ->Isolator switch->shower unit,
Or MCB->RCD->length of cable to isolator switch->shower unit, I suppose it don't matter either way but I was just wondering if there was a set procedure to run cable into a shower unit..
Also does an RCBO replace an RCD ? so can I have MCB->RCBO-> length of cable to Isolator switch->shower unit for example?
ofcourse I will get the installation certificated after the install I plan to install the cable ,consumer unit , new isolator switch and carry out the necessary Plumbing but not connect to MCB and let a local lecky sort that out and certificate it (as local lecky dont want to install under floorboards or in a wall he "prefurs" to stick horrible trunking up on my walls.) And seeing that I am more than capable of doing the rest then I will and save myself a bit of money and make a better job of it too...
Thank you in advance
