Vokera Maxin 24e Non running
29 Jan 2012
Berkshire
Started going wrong last Summer. The boiler would 'gurgle' when drawing hot water then stop. Got a local company out who charged me £200 to replace a valve. :twisted:
4 weeks later started doing the same thing. They then said it was the heat exchanger. I've lived with it because if I ran the tap slowly it would be ok.
Last week got a big 'gurgle' and then both the hot water and the central heating stopped.
2 plumbers have failed to turn up so here I am asking for help.
When I turn the boiler on, there is a quite humm but no ignition
Thanks for reading
Martin
Do you have water in the system - what does the pressure gauge read?
Mick
As far as I know there is water in the system. How would I check this.
The gauge reads zero out of 3
I dont know, exactly, what you mean by "zero out of 3".
The black needle on the pressure gauge should be between 1 & 1½ when the system is cold.
Mick, thanks for the pic, will look in a min and report back
Sorry for long Delay, been away.
Found the fill tap, got the pressure up to 3 on the gauge, have heating. Thanks for the advice. The lack of hot water from the tap is due to the Heat Exchanger. That will be replaced later this week
Mick, thanks again for your input
Martin
