I have had a new Worcester 30si fitted and had my old back boiler and immersion tank removed. Plus I've had a polypipe underfloor heating set up added to the new kitchen as a zone on the heating.
The plumber initially advised that I could choose any of the worcester controllers so I chose the FW100 weather compensated controller and this has been fitted in the hall to control the radiators in the house. The underfloor heating has it's own programmer.
The problem is that Worcester tell me the FW100 should not be set up in this way (something to do with the underfloor heating zone) and it needs to be fascia mounted, set to always on and if I want to control the rads I need a separate 3rd party programmable thermostat (or controller and thermostat) to control the radiator zone. (as per their technical bulletin TB 0014 http://www.worcester-bosch.co.uk/mobile/literature/technical-bulletins)
I asked my plumber for more advice and he told me I could use the worcester FR110 but worcester advised against it. I've therefore lost a bit of faith in the plumber so have been researching it myself. I am looking for one which can be set to different temps so a set back temp, comfort temp and frost protection plus different times each day or at least Mon-Fri and weekends. I'm not looking for RF as the current FW100 is wired in to the hall so I'm expecting to reuse the wiring when it's moved to the boiler fascia.
So my question (finally!) is what would be a suitable 3rd party programmable stat?
I'm considering the honeywell CM907 http://www.honeywelluk.com/products...tats/TPI/CM907-7-Day-Programmable-Thermostat/
Does anyone have any other proposals?
Would it work if I took out the FW100, sold it on ebay and put in a FR110 instead? I'm not sure the weather compensation is worth all this hassle!
Many thanks in advance.
Mike.
Mike.
