I bought a house from a national housebuilder which is finished in a coloured weber one coat render. The spec says that this should be finished to 15mm. Upshot is that it is falling off at the corners, and I dont think it is on thick enough. Image below shows render thickness compared to a 5p piece. Diameter of 5p is 17mm, so render should be almost same thickness - render is only about 3mm. Builder says it is impossible to get 15mm at corners due to bead. I say that they have used the wrong bead, but they disagree.
Could anybody on here give me any advice on whether the bead is wrong and render should be thicker right to corner?
Scottish Al
View media item 42767 View media item 42768 View media item 42769
Scottish Al
