As above really. Quite handy and will have an experienced builder with me (or rather the other way round!) so would appreciate any pointers as to whether there are any tricks to doing these, well, even a step by step would not go amiss just in case.
Have in the past fitted casement windows, but not in the UK, etc, so I don't trust the experience to necessarily be of any particular value.
Basically these latter were properly levelled and positioned in place with wedges, then they were screwed into the walls, IIRC with just 4 screws, mainly so they stayed put, then the gaps around the frame cemented and sealed or occasionally expanding foam was used. Not sure if the same principle is applied with box sash windows, and also would appreciate info about details such as isolating from the brickwork, etc, how that works out (if necessary), well, every tidbit will be gratefully received.
Looking to save on the installation costs, as the windows themselves cost enough already!
Also any idea how many we could realistically fit in a day, I'm saying 2 to be safe.
Thanks in advance, I will respond/keep you engaged a while, no doubt, just trying to keep this first post of the thread a bit manageable...
