http://en.wikipedia.org/wiki/Glass#Behavior_of_antique_glassSo I've been told too, aparantly if you look on really old stained slass windows in churches and the like it can be seen that is has "run".
Please ignore my quoted statment
That's exactly what I would have expected, but was interested in getting confirmation. I suppose what stimulated this is a fascination about the way that terminolgy has developed in the world of electricians - e.g. 'IR' testing will very rarely relate to 'insulation resistance' in the normal sense, whilst 'continuity testing' is a pretty ill-defined phrase ('continuity', in the literal sense, can exist in the presence of a resistance which is unacceptably high for the situation concerned).I doubt many of us will live long enough to come across PVC which has deteriorated, due to age, to the extent it fails an IR test. I have removed cable which has broken down to to external factors (favourite being sun damage to outdoor cables). We do come across peridhed VIR, but that's not really what you are asking about.
As I said, it's just paranoia, but I usually do - and started because a friend of mine claimed that he had come across some duff cable. As you say, it is really not much of a burden to me - 30 seconds work, very occasionally.I haven't come across duff cable, but that doesn't mean it isn't out there. Do you really IR test every drum? I suppose you could do that if you buy a couple each year.
It started, 3 or 4 years ago, as a very short-term experiment to settle an argument with a friend who seemed to believe that PVC T&E was not safe if it got wet. As time went by, it seemed a shame not to let the experiment 'go on for ever', just outvof interest, although I don't have much expectation of being able to measure an insulation resistance at any point in my lifetime!What exactly are you trying to prove with your experiment with your submerged cable?
I'd be interested to hear the results and, if I were a betting man, would probably bet on it being OK.In my round tuit box I've got a length of T/E which had been on a catenary to the garage for donkey's years. Nice and dry by now - one day I'll zap it, and then put it in a container of water for a good long soak and zap it again.
Thanks. As I expected.In my time I have never come across a cable that has naturally degraded enough to result in a low insulation resistance.
It's obvioulsy the case that no manufacturing process (or even the pre-release testing they should undertake) is infallable, so I guess there will always be some rogue cable being sold - but it seems to be incredibly rare. However, for someone who buys as little cable as I do, to test it all 'on arrival' is a trivial business, and therefore not a burden.The causes are commonly damage caused by third party. I do recall a friend having to rip out a newly installed cable that was faulty. He explained that on further investigation there was a fault within the cable that he put down to a fault in the manufacturing process. Maybe it is a good idea to test all new cabling prior to installation.
That's more-or-less the 'argument' which caused me to commence my ongoing experiment 3 or 4 years ago!I use to work with an electrician that was convinced the reason one would not necessarily install twin and earth outside was due to the rain.![]()
